1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1456399 06/25/2022 8:20 PM
I have a '47 GMC 228 in my 41 AK and it has started to "cough" when doing a smooth acceleration at between 1100 & 1500 rpm. Have check electrical, vacuum and other visible areas. Doesn't do it everytime does it about 50% of the time. Could a intake valve be sticking ?
ronsway #1456436 06/26/2022 2:05 AM
Change out your condenser or get one of Jon G's 200,000 hr jobs.
It may or may not be the problem but it won't hurt. Condensers ar pure junk these days - even brand new.
1950 Chevrolet 3100 (Ol' Roy)
ronsway #1456438 06/26/2022 2:51 AM
Where can I get one of his condensers?
ronsway #1456439 06/26/2022 2:53 AM
PM Jon G
ronsway #1456440 06/26/2022 2:54 AM
ronsway #1456467 06/26/2022 12:27 PM
ronsway #1456482 06/26/2022 2:05 PM
I had a bad lobe on the camshaft for an exhaust valve. When the intake valve for that cylinder would start to open it would cough up the carburetor. Would not do it when the engine idled.
Rick
1939 Chevrolet Stake Truck
ronsway #1457064 07/01/2022 4:56 PM
ronsway Might try a dose of marvel mystery oil in the fuel,check valve clearance,that condenser,look close at your valve action maybe spot a bad lobe,see if your push rods are rotating as it idles,plugs in good shape ?, carboned up on valve stem, accelerator pump may have a void before it shoots,exhaust system blocked ,maybe even a plug wire that's weak.
ronsway #1457071 07/01/2022 6:27 PM
I got a condenser from Jon G. (thanks). I haven't had a chance to try. Thanks for add'l info will keep working on it.
ronsway #1457109 07/02/2022 2:48 AM
Have you pulled/inspected the spark plugs?
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
ronsway #1457122 07/02/2022 4:35 AM
I put the condenser in took the truck for a ride...the "cough" didn't happen???
Flatblu4748 #1457942 07/08/2022 11:37 AM
flatblu4748 You know I never hardly ever look at my plugs,use HEI on about 5 235 engines and for several years too. I look and they're rusty from not being even turned.
ronsway #1457943 07/08/2022 11:40 AM
Looks like you may have solved the problem. How many miles on the other condenser?
Next step, get one of Jon G's Condensers.
ronsway #1457959 07/08/2022 3:43 PM
I guess about 1000 miles. I am sure it was Chinese , got it a NAPA store.
ronsway #1458004 07/09/2022 12:42 AM
Ya, they're all Chinese crap. My NGK condenser failed in 1500 miles.
