4 members (JW51, rfs56trk, Cosmo, 1 invisible),
119
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 34 Junior Member | | Junior Member Joined: Oct 2005 Posts: 34 | '29 Chevy 1 ton rear wheel removal
Does anyone know how I remove the rear wheels on a 1929 Chevrolet 1 ton? I removed the hub cap. Removed the big nut w/ cotter pin. But what happens next? the wheel doesn't just pull off. Does it get pounded off? or is the some sort of gigantic puller?
Frank 1949 Chevy 3800 1929 Chevy International
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Frank, Your rig is REAL old...I have stuck in a link to a site that has tons of information plus illustrations. Sometimes if you can see what is involved, you can figure out how it comes apart. http://chevy.tocmp.com/1929_54chevyparts/index.htm Stuart | | |
