1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#1455632 06/19/2022 5:04 PM
Need help . Have tried to find bolt size for the front bed panel to mount sides. Also does anyone know the the size and length of the front bed panel ROD. Thanks for help
According to Mar-K's website link they would be 1/4-20 x 5/8" hex head bolts.
I was waffling between 1/4-20 and 5/16-18 till I looked. My memory isn't that good, since I took my bed apart 5 years ago. wink
Fox Offline
I removed my front panel rod. I’m not sure if you’re in bare steel or not, but this is what I did. My panel was home built, so I drilled a 1/4” hole in a frost plug, bolted a 1/4 bolt through it with a nut, welded the nut on the backside, removed bolt, then plug welded the frost plug into the upper front panel tube. Viola, no more 4’ rod flopping around inside. It makes it so much easier to assemble the front portion of the bed.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
