11 members (Rusty Rod, klhansen, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 3800GUY, Oswald, Wally / Montana, 1 invisible),
49
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,911 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | Need help . Have tried to find bolt size for the front bed panel to mount sides. Also does anyone know the the size and length of the front bed panel ROD. Thanks for help | | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | According to Mar-K's website link they would be 1/4-20 x 5/8" hex head bolts. I was waffling between 1/4-20 and 5/16-18 till I looked. My memory isn't that good, since I took my bed apart 5 years ago.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I removed my front panel rod. I’m not sure if you’re in bare steel or not, but this is what I did. My panel was home built, so I drilled a 1/4” hole in a frost plug, bolted a 1/4 bolt through it with a nut, welded the nut on the backside, removed bolt, then plug welded the frost plug into the upper front panel tube. Viola, no more 4’ rod flopping around inside. It makes it so much easier to assemble the front portion of the bed. | | |
