7 members (TexasA&M48Truck, Nick in Manitou, UtahYork, Ponchogl, Peggy M, 2 invisible), 104 guests, and 4 robots.
Topics128,077
Posts1,056,014
Members48,433
#1455168 06/15/2022 1:25 AM
Is there a brand of body filler that is easier to work with than 3m bondo like you get at Walmart?
I remember seeing some videos on YouTube that looked like it went on easier and smother but I don’t know what brand they were using or it could be my novice body work. My truck is a big bolt, if it was a 1/2 ton I would hire a pro to do it.
1950 4400
Joe Alan #1455178 06/15/2022 1:58 AM
I was recommended to use USC All-Metal by a body shop owner. I've used generic brands and they all (including All-Metal) seem to sensitive to base/activator mixing ratio. Not enough hardener and plan on removing it when it doesn't set up completely.
The All-Metal is OK to spread, but can be a pain to sand. I've used Eastwood Contour Finishing Putty (also needs hardener) and I'd rate it just a touch above All-Metal, but it's way more expensive and shouldn't be used except for very small dings.
Joe Alan #1455222 06/15/2022 3:47 PM
I am not at home to be 100% sure on the name. Friend of mine who does bodywork had me buy EZ Fill or EZ Sand. Something like that, but I will confirm tonight for you. He loves it cause it can be sanded quickly, and it remains easily sandable once fully cured.
Compared to other fillers this has been a godsend for me. Had to purchase through my local autobody paint supply store. Make sure you know someone who can run it through their account or you will fall over from the price.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
klhansen #1455225 06/15/2022 5:01 PM
Yea I thought about Eastwoods body filler,saw some videos on YouTube and it looked like it went on well but they are murder on shipping charges.
Thanks for the help
1950 4400
Joe Alan #1455226 06/15/2022 5:01 PM
If you're having to apply filler more than 1/8" thick , you haven't done enough metal work. Body filler is not a substitute for skill at shaping metal and/or straightening dents.
Thanks I’ll check out the EZ Fill
1950 4400
Joe Alan #1455230 06/15/2022 5:20 PM
I used to use Rage Gold. I have absolutely fallen in love with 3M Platinum. Sands like butter!!
Agreed. I'm shooting for 1/16" thick, but a couple spots needed a bit more.
Joe Alan #1455292 06/16/2022 1:26 AM
This is what my body guy told me to use.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
Joe Alan #1455409 06/17/2022 11:34 AM
Rage Ultra and 3M Platinum (NOT Platinum Plus) spread and sand super easy. The Platinum is a bit cheaper than Rage Ultra. Never had pinholes in either when mixed properly.
Mason
1947 Chevy 3100
-57 Chevy 235
-95 S10 T5 Transmission
-97 Blazer 3.42 Rear End
