7 members (KEVINSKI, ronsway, Otto Skorzeny, Greg_H, 1955 1 Series, TrknGMC, TooMany2count),
157
Mod | | | Forums66 Topics128,142 Posts1,056,481 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 18 | Looking for where to buy booster/MC assy.for 39 panel truck. I see Ebay has but ridiculously priced compared to similar units, tia. | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | I would guess the 1939 1/2 ton panel truck uses the same master cylinder as a 1939 1/2 ton truck. The Master Parts List says 1 inch diameter master cylinder 1938-1946 for a 1/2 ton. Cast number 5450256. Part number 5454575 correction 5454576. Is this what you have now?
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Jan 2022 Posts: 197 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 197 | I would guess the 1939 1/2 ton panel truck uses the same master cylinder as a 1939 1/2 ton truck. The Master Parts List says 1 inch diameter master cylinder 1938-1946 for a 1/2 ton. Cast number 5450256. Part number 5454575. Is this what you have now? The Cast number 5450256 is good but the Part number is 5454576 Chevs of the 40'S has a new one for 178.50. Chevs of the 40'S | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Thanks for the correction. It's getting harder not to make mistakes.
The poster wants booster and master cylinder. No other info provided so assume: * 1/2 ton front and rear drum brakes * Dual reservoir * Probably 7" booster (if it will fit) * Cutting extra hole in floorboard to access new master cylinder fluid fill
