0 members (),
126
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 160 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 160 | I have a 216 head and would like to know which head I saved . I scrapped two engines years ago and hope I saved the one from the ‘40s. Part number is 839401 or 889401 below is the number 4.
I invest my money in precious metals, mostly rust!
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 |
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Sep 2019 Posts: 160 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 160 | The exact year isn’t necessary, just the general idea. I know that a couple of years of the ‘40s the head was different with smaller spark plugs. The head is in my junk shed and I did good to photo what I did ( dropped the phone and played hell to retrieve it without pulling half the junk out of the shed!). It’s not a big deal, just a curiosity thing.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Any 216 head from 1941-53 will fit and function the same. As you mentioned the earlier heads used 10mm plugs. The 1937-40 heads are designed to go with dome pistons, so they are not a good candidate. The 1937-40 head can easily be identified as it is straight down the manifold side, not scallop around the head bolts like the 1941-53 head.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | Question for Dave- - - - -can the heads with the 10MM spark plugs be drilled and tapped for 14MM? I've got a few of the small plug heads stashed away, and those plugs are scarce and E$$$$$PENSIVE! Jerry
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I wish I could answer that Jerry. I have not tried that.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | It sounds like it's time to set up a head on my valve seat and guide machine so I can get the alignment of the plug holes all the same, and try it. It should be fairly simple to spot-face the gasket surface so the bigger seal ring will work, and then use a piloted drill bit to prepare for tapping a new thread. Unless I end up with a water cooled combustion chamber by hitting a coolant passage, it seems like it would be a good way to enhance the dwindling supply of 216 heads. Once I get a running prototype going of a full pressure oiled 247 cubic inch "216" the demand for these old engines just might increase dramatically. Jerry
| | | | | Joined: Sep 2019 Posts: 160 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 160 | Go Jerry Go! Let’s see what you can do for these old engines. I hope I tossed the 10mm head. I wouldn’t want to spend the extra money for the plugs.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Rusty HEAPS Better be patient about the time you throw something someone will come along and give you a box of those 10mm plugs. | | | | | Joined: Sep 2019 Posts: 160 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 160 | I tossed out a lot of pieces, parts 10 years ago when the codes official tagged my cars and told me to clean up my pile of miscellaneous junk. Had I known then I would have saved more.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Rusty Heaps You need to move out in the wilderness where the "feds" won't bother your "heaps". My iron pile is getting more valuable as time wears on . Found a can full of AD light switches where I just cut the wires saved the nut and the knob. Spray the switch interally with WD 40 and your ready to go !! | | | | | Joined: Sep 2019 Posts: 160 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 160 | I’ve been looking at homes that are a bit more in the wilderness than where I’m at now!
