1 members (Otto Skorzeny),
115
0
Mod | | | Forums66 Topics128,049 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Does anyone remember an article or a picture here on Stovebolt regarding a plywood platform used to make working under the dash a whole lot easier? I've searched and searched but no luck! I wanted to help one of my brothers make something like it. Thanks, Jim | | | | | Joined: May 2015 Posts: 11,017 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,017 | I'm going to have to work under my dash (hopefully soon.) I'll probably leave the seat frame out and put a piece of plywood on the riser with some blocks at the front of the floor to level that up. Shouldn't need to "build" anything. I don't fit on the floor in front of the seat riser, so need more room that's flat.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | I just cut a 2 foot wide piece off a 4X8 foot piece of 1/2" plywood and build a 2X4 framework to support the outboard end at rocker panel height. Prop one end onto the floorboard, and lie down to work under the dash. Try not to snore! Jerry
| | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | OK, I know this isn't a difficult project to figure out but I was hoping for a helpful photo to send to my brother. I'm sure he can make something work just fine! Thanks. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I made one like HRL describes and the first time I put it in, I just laid there for a while with a smile on my face and thought about just nodding off.
