2 members (qside, 78buckshot),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | I have a question; how often do you overhaul your carburetors? Or what criteria do you use to determine that a repair is required? I have a Carter that I installed 3 years and about 2500 miles ago and am contemplating overhauling it. I have no issues with the carb and my milage is close to 20 mpg, so I have no complaints with how it is running today. I do run regular gas in it, so there is some ethanol involved, but with the new kits these days I presume there are no issues with incompatible parts. I put between 800 and 1000 miles per year on the truck, just drive it when the car is unavailable or I have something to haul. Curious what everyone does and why.
Thanks, Lee.
1956 Chevy 3200, 235 w/3 speed
| | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | As long as things are working correctly there's no need to touch them.
I rebuilt the Carter 4bbl in my Cadillac over 15 years ago and it runs like a Swiss watch.
Just don't let the ethanol gas sit in the fuel system for a long time.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | I drive it fairly regularly; the winters here are mild and dry, so I can drive all year long. The summers are tough, but with 240 air conditioning, I stay comfortable.
| | | | | Joined: Oct 2021 Posts: 6,772 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,772 | Regular driving is the best preventive maintenance you can give any vehicle.
A friend of mine oversees a large local car collection. The vehicles range from the 1910s to the 1970s with heavy emphasis on the 1930s Classics, including a couple Duesenbergs.
Every single vehicle in the collection is subject to a 3 hour drive on local roads at least once a month. This keeps everything lubricated, the fuel system fresh, etc. It's quite amazing to see a 1934 Duesenberg or 1918 Cadillac driving through town in regular traffic.
Anyway, at a natrional show (either Hilton Head or Pebble Beach, I can't remember) the Duesenberg Town Car was competing against other Duesnebergs (they're in a class by themselves, of course). The presumptive winner was a roadster. After all, who doesn't like a two-seater over a stodgy , formal limousine?
The other owner didn't subject his vehicles to regular use and the roadster failed to start and run on the show field. The top prize went to the town car as a direct result of the opposition's lack of regular use.
| | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | I suspect that a lot of carbs are needlessly rebuilt. I rebuilt a carb and as I was looking at it, I thought that it seemed pretty clean. Turned out that the carb was not the issue.  OTOH, I had a Q-jrt that needed rebuilding every couple of tears. This was a daily driver. I wouldn't idle properly and the turning mixture needles in and out had no effect. Finally got tired of it and got an AFB and had no trouble after that.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2014 Posts: 4,483 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,483 | I make it a habit to look inside mine every year or two. Usually I'll find it is ok, but I like to be certain things are clean and the diaphragm is still good. You may need to remind people about the 240 A/C. About this time of year it doesn't always work as well but then in October it gets good again.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Don't fix what's not broke! Drive it regularly and carbs should last for a couple of decades at least. Jerry
| | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | You’ll have more trouble in Dallas than I do here in Angelo; between the higher humidities and the traffic… I guess I actually have 640 A/C; 2 windows, 2 vent windows, and the 2 floor vents.
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | I really think they should be rebuilt daily!!!!!!!!!!  And I know where you can get repair kits  Seriously, the genuine Carter AFB's on my shop truck have been trouble-free for 22 years. Unless you really enjoy doing your carburetor, leave it alone until it gives trouble. Jerry beat me to the old cliche: if it ain't broke, don't fix it! Jon Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Gord n Fran on your Q-jet they really like a new float every so often. | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Growing up, we had an early 1960's Farmall 140 tractor that saw endless hours of grass cutting about 15 acres in the summer with a 5' belly mower, pulling firewood on a trailer in the winter, and anything else we needed it for. We ran it for 16 years and never touched the points ignition system or the Zenith carburetor, and it ran smooth as silk when we sold it.
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
