5 members (Otto Skorzeny, Hotrod Lincoln, TUTS 59, klhansen, Snowman51), 69 guests, and 3 robots.
Topics128,099
Posts1,056,501
Members48,444
Page 2 of 2 1 2
If shorting the sending unit wire to ground with the key on does not make the gauge read empty, try shorting the gauge terminal at the other end of that wire to ground. If the gauge then reads empty the wire from the gauge to the sending unit is open and needs replacing. JUST MAKE SURE YOU DO NOT SHORT THE POWER TERMINAL ON THE GAUGE TO GROUND. SMOKE MAY OCCUR.
Back to my question in the last post on page 3. I need some clarification on how to best access the fuel gauge (i.e. how to drop the cluster) to perform some of these tests.
Doing it “by feel” probably isn’t the wisest approach, now that I think about it.
Which “side” of the gauge has the wire coming from the sender and which “side” has the power supply?
1951 3100
Remove the nuts holding the gauge cluster in (the tabs sticking out the sides) and it will come out the back. You'll have to deal with the capillary tube from the temperature sender and connected wiring.
There should be a tag on the terminal to connect to the sender. See the attached pic.
GAUGE CLUSTER BACK VIEW
Perfect!
1951 3100
Crusing in the Passing Lane
A set of nut drivers are a useful tool to have!
Ed
Page 2 of 2 1 2
