| | | Forums66 Topics128,288 Posts1,058,568 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 728 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 728 | Question:. If an engine starts right away, with just a few rotations, is that a sign of decent timing? | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Normally yes. Starting easily and accelerating without hesitation or pinging is a fair indicator that things are set right.
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Starting well, even with a cold engine, can be a indication of good cylinder compression (piston rings to cylinder wall contact). For example, an engine with worn rings can be harder to start.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | |
