5 members (Youngin' Tut 59, klhansen, DadsFirstPickup, BarryP, 1 invisible), 73 guests, and 2 robots.
Topics128,139
Posts1,056,758
Members48,454
My 51 truck has a later open diff that I have recently identified as the 55-62 1/2 truck rear (with the board’s help).
Anyway, it leaks from seemingly every orifice, but is pretty scabbed over and not dripping much at present. I will tear down and reseal but would like to just drive it as it is for the summer.
I would like to clean up the vent so that it can do it’s venting thing. Was there supposed to be a hose attached like a more modern diff vent would have?
1951 3100
Usually vents of that era were just a fitting with a small cap over the top. But there's nothing stopping you from attaching a hose and extending the vent up to the frame.
Make sure that the vent is really venting. Over time dirt can build up in the cap and plug it. The cap should be free to "wiggle" on the stem that fits into the axle housing.
Rusty
Crusing in the Passing Lane
If the vent is stopped up, it will force oil out any lower orifice every time it gets warm, until it is all gone.
Ed
You're lucky. My vent was completely gone when I got the truck. Not sure how long it was gone for, but I found rocks in the diff when I opened it and the oil may as well been tarsand.
I used a brass barbed fitting and pounded it in the hole. I am going to do a simple hose up to the frame with a coil to keep the dirt out.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
I've got that beat. Some previous owner put a pipe plug in place of the vent fitting. A guarantee of soaked brake shoes and gunk all over the differential.
The hole should be threaded with 1/8" pipe threads.
Klhanson.
My hole was smooth. Thought about threading it, but then I saw the brass barb fitting at the hw store and said sold.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
Project Journal
JW51 If you put a hose on your vent need to fix it so muddobbers wont fill it up. Can screw a coarse stubby set screw in the hose so it can vent thru the threads. Or screen it somehow.
