| | | Forums66 Topics128,086 Posts1,056,333 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Can anyone comfirm this horn as being correct for the Task Force Trucks? I can't find this part number in any of my books. I've asked the owner and he's checking is information also. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=8022027059&sspagename=ADME:B:AAQ:US:1 Thanks! Mike B  | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mike, your right I can't find that number in my books either Canadian or American. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the TF light trucks didn't have the long trumpet, at least not standard, and there isn't any other style listed as an option - also way different part # - may be an optional thing for mounting outside the cab on big trucks, or from earlier years
Bill | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The instruction sheet he has shows it mounted below the drivers side horn on the core support pointing at the ground. The sheet is dated 8-55. He says it's not marked "12v" either which makes me think it's a 6v unit. Mike  | | | | | Joined: Sep 2005 Posts: 30 Member | | Member Joined: Sep 2005 Posts: 30 | Listed as part # 9874443. Looks like a sticky #4 key on the sellers keyboard..
I did find GM part # 987443 in my book.
It indicates " 1956 Horn unit- vibrator-passenger " | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I still don't have it shown in my 1929-1959 Parts Book. What book did you find it in? Thanks! Mike B  | | | | | Joined: Sep 2005 Posts: 30 Member | | Member Joined: Sep 2005 Posts: 30 | Found it in my 1946-1978 numerical accessory parts list. | | |
