Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Donf, redskins1), 189 guests, and 4 robots.
Topics128,288
Posts1,058,569
Members48,492
Page 3 of 3 1 2 3
Question:. If an engine starts right away, with just a few rotations, is that a sign of decent timing?
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
Normally yes. Starting easily and accelerating without hesitation or pinging is a fair indicator that things are set right.
Curmudgeon
Curmudgeon
Starting well, even with a cold engine, can be a indication of good cylinder compression (piston rings to cylinder wall contact).
For example, an engine with worn rings can be harder to start.
Page 3 of 3 1 2 3
