6 members (CATMAN, tclederman, BarryP, DadsFirstPickup, Bill Hanlon, Millenimech), 95 guests, and 4 robots.
Topics128,154
Posts1,056,842
Members48,456
Which way is this turnbuckle adjuster supposed to be facing?
Concave side up? Or concave side down?
This one was facing down when I started but who knows what's been done to the truck in the last 70 years?
1950 Chevrolet 3100 (Ol' Roy)
I thought I had a picture of mine before I removed it, but don't. I recall that mine was facing down. Even thought I have Bendix brakes, I don't think that matters.
Hi Kevin.
They'll probably work regardless of orientation of the turnbuckle thing but if it didn't matter, I suspect they'd have built the adjuster with straight legs instead of curved ones.
Also, why are they called Huck Brakes?
2 Offline
Concave goes up
The point is to clear the rod that is pulling on it.
With concave up when it’s reaching limit travel you get a tiny bit more out of it before it crashes into the big rod
You see this curve detail on locations similar to this action in many places.
-s
Huck was the company that designed and supplied them to GM. In later years (51 and up I think) GM changed to Bendix designed brakes.
Re-oriented parking brake adjuster and new clevis pin
Otto,
These may be of benefit to you.
Harold
SHA1: 977592df66ccff0e07d2cfe40586a8a4e8347ce4
SHA1: e4036f2078f37c631989b3d16274dc900c3b55e9
Harold
