| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 17 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 17 | I have a 1965 C10 I have at the body shop going back together, now they say the front corner is 2 inches too low and the frame needs to be straightened so fender and radiator support will bolt up. I'm not sure what to do. I've put a lot of money and time into this build. What other truck frames that will fit under this truck, or just purchase a custom frame kit. Any info or suggestions would be great. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | It’s a lot less expensive to straighten a frame than to replace it with something else.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I supposed you asked more and went to investigate to see where it is "bent". Hopefully they know what they are doing, BUT YOU NEVER KNOW! Could be a suspension issue. I hope you didn't just let it go with "front corner is 2 inches too low".
IF: 1. You are going by just a phone call 2. You didn't notice that when it was all together at your house 3. You don't know much about this shop ............I have some advice. Pray tell.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | Fist check the coil spring to see if it broken.
If a frame needs to be straightened it should be easy to do right there at the body shop. They should have a port a power. If not then they have the old way of pins in the floor and turn buckles. | | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | JDM777 I have no advice on your frame, but if you don't mind, I would like to hear about your process for your C10, as I'm also working on a 65 C10 and will be engaging a body shop/restorer in the not too distant future, hopefully. I have mine stripped down to the frame except for cab, which is still in place. I'm back and forth on cab removal.
Kevin 1965 Chevy C10 Longbed Fleetside
