4 members (Southerntruck, Samantha, TUTS 59, tclederman), 106 guests, and 3 robots.
Topics128,036
Posts1,055,458
Members48,422
#1451385 05/11/2022 9:22 PM
I have a 1965 C10 I have at the body shop going back together, now they say the front corner is 2 inches too low and the frame needs to be straightened so fender and radiator support will bolt up. I'm not sure what to do. I've put a lot of money and time into this build. What other truck frames that will fit under this truck, or just purchase a custom frame kit. Any info or suggestions would be great.
It’s a lot less expensive to straighten a frame than to replace it with something else.
Sir Searchalot
Sir Searchalot
I supposed you asked more and went to investigate to see where it is "bent". Hopefully they know what they are doing, BUT YOU NEVER KNOW! Could be a suspension issue. I hope you didn't just let it go with "front corner is 2 inches too low".
IF:
1. You are going by just a phone call
2. You didn't notice that when it was all together at your house
3. You don't know much about this shop
............I have some advice. Pray tell.
Fist check the coil spring to see if it broken.
If a frame needs to be straightened it should be easy to do right there at the body shop. They should have a port a power. If not then they have the old way of pins in the floor and turn buckles.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
JDM777 I have no advice on your frame, but if you don't mind, I would like to hear about your process for your C10, as I'm also working on a 65 C10 and will be engaging a body shop/restorer in the not too distant future, hopefully. I have mine stripped down to the frame except for cab, which is still in place. I'm back and forth on cab removal.
1965 Chevy C10 Longbed Fleetside
