8 members (JW51 , Woodcmiami , Gdads51 , dt235sd , MickeyP , HandyAndy , k2handyman , 1 invisible),
58
robot. Key: Admin ,
Global Mod ,
Mod
Topics128,049
Posts1,055,699
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Just want to thank y'all for the input.. Here are some pics of whats going on. I will add another post with more.
'38 1.5ton; "The stuff is as tough as woodpecker lips"
Some details.. as y'all know, wanted to go faster than 45mph safely.. - removed 216, added 292 after some fabrication for size (longer), 4bbl carter per this forum. - added nv4500 5 speed - added dana60 rear - added solid floor also to fit trans - replaced rims and wheels with 19.5" and radials, - converting to 12v - keeping original ;paint - repaired pin holes in roof - was fire truck at one time, must have had sirens and lights.
Crusing in the Passing Lane
Thanks.
