1 members (Guitplayer),
85
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | The manual states it can weigh gross 13,000+ with dually tires.. I *think* it weighs 6000#.. that leave 7,000+ = 3.5ton..
'38 1.5ton; "The stuff is as tough as woodpecker lips"
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Search this site for lots of reading, it's been discussed before with no official answer... Mike B  | | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | okay. I wasnt sure which words to couch this that would come up. Will give it a try! https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1443402/1.html <-- found using 'weight' instead of 'rating' .. consensus they can hold ALOT more, as the manual states.
| | | | | Joined: Feb 2016 Posts: 1,997 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,997 | Years ago the nominal capacity of the truck was based on the front axle weight capacity, I think my '57 2 ton has a front axle capacity of 4000 or 4400 lbs. - 2 tons. The truck has a GVWR of 16000 lbs.
| | | | | Joined: Nov 2000 Posts: 1,974 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,974 | I am not sure that is correct 78buckshot. Though I have read that before. I think it’s a carry over from a very early truck capacity rating system.
Professional Novice
