7 members (Gdads51, Hugh63c10, moparguy, 32Fordpuchoptop, Hanks custodian, ShopRag, Ponchogl),
138
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2020 Posts: 102 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 102 | I saw the info on how to make your own short throw shifter, however, it did not show the drill size for the hole. Does anyone know what the drill size is for this pivot pin?
1963 C20, 292 (4.8L). 4-speed.
| | | | | Joined: Mar 2014 Posts: 4,499 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,499 | Memory is telling me it was 5/16" but you really need to check me on that. Some stuff was metric with the T5. Personally I'd have a machinist cut the hole for you. It needs to be done right the first time and it isn't all that easy to do with just a drill press.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
