5 members (Steelonsteel, Hotrod Lincoln, 55shaker, ShopRag, 78buckshot), 100 guests, and 1 robot.
Topics128,035
Posts1,055,552
#1449464 04/26/2022 4:24 AM
I was looking at my 42-46 GMC panel truck today and I am now confused. I don't have a title or data plate for it so I do not know year of manufacturing. I know it is not a 41, I have several of those so I know the differance. The stamped number on the passenger side frame rail is CC 101 22242. I first thought it meant my panel was built on 2-22-42 but after some searching I found civilian production ended on 9 Feb 42. Is this just the 22242nd panel off the line? Any clue as to what year I am dealing with? Just thought about something, I am going to see if I can read the numbers on my 41 GMC pickup. Any help here? Dave
Just found another resource, seems my panel was made some time in 1945. Wish I knew more about it.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Sir Searchalot
Sir Searchalot
I see you say it's a 45. GMC's typically DID NOT have frame stamps. Maybe it's factory, maybe someone marked it.
homer52 #1449479 04/26/2022 12:23 PM
Rob English (who I think qualifies as a GMC guru) posted this GMC serial number decoder over on the OldGMCtrucks web site that has a bit more detail.
GMC truck model identification.
This page shows that GMC did use frame stamped serial numbers on earlier trucks.
Serial number locations
Source is:
Crusing in the Passing Lane
‘37 GMC trucks did have frame stamp numbers, r side, outside of frame, by front wheel.
Ed
That is the exact location I found the CC-101-22242 , decoded meaning my panel was built in 1945.
1941 Chevy
Sir Searchalot
Sir Searchalot
Good to know. Early were stamped. My 55.2-66 GMC trucks were not.
