Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
8 members (49nut, Grandpas_48, klhansen, tclederman, Hotrod Lincoln, Steelonsteel, frogfarmer, plane_fixer), 554 guests, and 1 robot.
Topics126,780
Posts1,039,295
Members48,100
Most Online2,175
Jul 21st, 2025
After going through several threads I think I know what the engine is except the engine #.
235 cast July 31, 1957
My guess on the 4th pic of the engine ID is F806H 1131397. I couldn't find another one stamped like this.
Please grade my home work
In my younger years I worried about the return on my principal now the older I get I worry about my principal being returned.
Curmudgeon
Curmudgeon
It has been double stamped. The original block may have been replaced with a new one.
Does any of the block stamped numbers agree with your title and/or VIN tag?
No
Title and vin match but look like engine numbers which I know was not unusual back then. I had a 51 that with that way.
This truck is a 2nd series 55.
Block and Head casting codes and Block and Head date casting codes cannot be changed without the attempted changes being obvious.
However, it is not uncommon to find odd looking Engine Serial Numbers - these were codes stamped into that "ledge" on the block when the engine was placed in a truck/chassis on the assembly line.
That stamped Engine Serial Number could be ground-off and a different code could be stamped on that ledge. Or, a second Engine Serial Number could be later stamped on that ledge.
The factory stamped 235 engine code F806H is from a 1957 3000 series truck...Chevrolet stopped putting serial numbers on their engines at the end of the 1956 model year.
F = Flint Engine Plant
8 = Month
06 = Day
H = 1957 235 for a 3000 series truck
The hand stamped number doesn't match any Chevrolet factory number format I've ever seen...it could have been from an engine rebuilder or State issued for some reason.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1956 8400 Wrecker w/Holmes 525
1956 9200 Tractor w/Allison Automatic
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 Jeep CJ-5 Navy Jeep
1984 Jeep CJ7
Hughesville, MD
Curmudgeon
Curmudgeon
Give the man a cigar! Thanks Mike.
Thanks for the help!
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.031s Queries: 17 (0.028s) Memory: 0.6211 MB (Peak: 0.7075 MB) Data Comp: Zlib Server Time: 2025-09-22 20:09:58 UTC
Valid HTML 5 and Valid CSS
