8 members (Rusted Nut, jmoore, Pre '68 Dave, cmayna, Gray_Ghost, 68ironhead, DadsFirstPickup, Woodcmiami), 92 guests, and 4 robots.
Topics128,259
Posts1,058,297
Members48,485
#1448845 04/20/2022 7:02 PM
Is there a way to determine whether an old style, (foot operated), starter is 6 volt or 12 volt, from the numbers on the ID label?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
If it's the original tag, a black one would be 6 volt and a red one 12 volt.
You could also look for the numbers on the part list. Link
Mike Burns Not many 12 volt out there, but a few. The 6 volt starters easy to rebuild if you can land the parts.
Also 6v starters will work and tolerate 12v with no real issue other than they spin faster…….which is feature not problem.
Sir Searchalot
Sir Searchalot
Yes, There is a way: Diameter of exposed end of pinion shaft.
Dusty53 reported 12V= .4787 and 6V= .5625
Thank you so much. That’s the info I was looking for.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
bartamos .5625 is 9/16 ths.
Sir Searchalot
Sir Searchalot
Fixed it.
