0 members (), 75 guests, and 3 robots.
Topics128,211
Posts1,057,475
Members48,473
Hi All,
As title, is it rocket science to have a cable made to fit the nv4500 slave cylinder end from a 94/95 chevy nv4500 5 speed trans to a tilton master (screw in) set up?
'38 1.5ton; "The stuff is as tough as woodpecker lips"
Most parts stores make up hydraulic lines. They have a large assortment of fittings and can usually match up what ever you need. Always good to have sample ends so the newbie at the counter can’t screw it up.
