5 members (klhansen, Otto Skorzeny, Wayne67vert, Frank50, TrknGMC), 67 guests, and 4 robots.
Topics128,076
Posts1,056,009
Members48,433
#1446256 03/28/2022 12:29 PM
Crusty Old Sarge
Crusty Old Sarge
I just installed an after market front sway bar on my 59' chassis, I had a few issues get things to line up and in the end actually made my own lower brackets. DB Cooper shared a picture of his sway bar install and it's completely different than mine. So the question is did the vendor sell me the wrong kit or are there multiple kits that will work?
My Sway Bar
DB Coopers
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
I am worried that yours is going to bind on the bottom of the crossmember once you load the springs. Or is that just the angle of the picture?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Yes, you need load on the springs before installing sway bar.
Body and engine
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Crusty Old Sarge
Crusty Old Sarge
Everything clears when the weight is on the chassis. I haven't tightened anything as yet, I'll wait until everything is mounted and bounced a round a bit.
Doing some research and it seems there are a few different designs for the 55.2-59. That one I have is a larger diameter than some of the others. Most of the ones I see are similar to DB's install. I'm not certain either one is right or wrong just different.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
I made my own sway bar and brackets and mounted it exactly like in the first picture. With the weight of the truck on it.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
Where did you get those bars? They look bigger than most I've seen.
Crusty Old Sarge
Crusty Old Sarge
John, I bought the the one in the first picture from Brothers Truck, and I believe D B bought his (the second picture) from Classic Performance Products.
Mine is 1 1/8 inch diameter, I'm not sure what size D B's is.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
