5 members (Otto Skorzeny, Wickedbass, Hanks custodian, 32Fordpuchoptop, Gdads51), 67 guests, and 2 robots.
Topics128,094
Posts1,056,048
Members48,433
#1445354 03/21/2022 12:53 PM
Front and rear, are there torque specs for the various suspension parts on the 46 1/2 ton pu? Or is it tighten until good and tight? Leaf spring U bolts, various shackle bolts, ect. Shop manual refers to assembly but no mention of torque.
Ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
I redid a 46 3/4 ton GMC and just tighten until good and tight with the exception of the engine and transmission . That was two years and 3000 miles ago and all is well.
1946 with WWII 270
Torque to current manufacturer specs for size and thread.
Sir Searchalot
Sir Searchalot
Tighten until your elbow clicks.
I agree with Mark
Read the notes at the bottom of this TABLE
Also, no reason to lubricate threads. Messes up the torque.
Improperly tightened U-bolts can lead to premature wear/breakage of the leaf springs. By not tightening per the specs you're allowing the spring to flex and crack at the centering bolt hole. Always torque then per the specs...check out this link for all you need to know about U-bolts. You also don't want to reuse U-bolt as they won't have the necessary clamping force the second time around.
https://www.suspensionspecialists.com/techinfo/Ubolt_Information.pdf
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Sir Searchalot
Sir Searchalot
Ed,
Ubolts are just bolts. You tighten them to the specs for the size and thread pitch for Grade/material used. I.E. Gr 5./1541
No oil.
Torque per Marks suggestion, my table and the table in the link by Mike. It's all the same advice and numbers.
All the rest in the link is,
French: Gobble de Gook
Latin: Non Est Bonum Quod
"tighten it until it breaks, then back off 1/8 turn' - quote from my Dad sometime back in the late 50's.
I usually back off 1/2 turn. grin
I read somewhere recently, that there is a torque spec for the mounting bolts for the front springs, front and rear eye bolts. The rear bolt gets torqued as it threads through both sides of the mount and the retaining nut has a torque value as well. The front shackle center bolt is also torqued. Anyone have any info on this?
As for ubolts and the spring perch torque, I received this bit of info. Hope it helps someone.
Ed
Sir Searchalot
Sir Searchalot
Torque your bolts/Ubolts per any reliable torque table you want, per grade/material/size/pitch. See above posts. Bolts is bolts.
