5 members (Gdads51, Jon G, DadsFirstPickup, 1955 1 Series, Wrenchman), 110 guests, and 2 robots.
Topics128,118
Posts1,056,305
Members48,439
#1446292 03/28/2022 8:00 PM
Thinking about welding the two pc Gmc hood together for strength. The center strip moulding would still be used. Whats your opinion on that?
1952 GMC
Starting with a basket case
In the Project Journals
1967 GTO
1967 Firebird
pauld #1446323 03/29/2022 12:52 AM
I think unless you just spot welded the flanges together in place of the rivets, you'd be likely to warp the hood. Too much chance of that in my mind to do more than a few spot welds.
Insomniac
Insomniac
Yes, we welded the two halves together and eliminated the centre strip so the hood is smooth. Unfortunately, we worked too fast welding it up and warped the hood just like Kevin warned. It was a PITA to fix.
Don't just grab the MIG and run a continuous bead like you are working on a pipeline. Stitch welds with plenty of time to cool is the way to go.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I learned the slow and steady on welding sheet metal this winter. Bounce all around. When you are ready to go back to the first area, stop and wait some more.
Should be able to do it. Not sure if I would have the skill yet.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
Not too worried about the warping from heat, done a lot of body welding. probably would only tack it about every 6 inches, blow air on the weld right away usually works well. I already have drilled out and re-riveted the hood, seems pretty good.
Just wondering if it was worth the effort for increased hood strength or just leave it factory.
1952 GMC
1967 GTO
1967 Firebird
Insomniac
Insomniac
Doing it for increased strength would be a waste of time, IMO.
We did it because:
-Centre strip was rusted and we didn't want to get a new one.
-Welding it up and filling the gap keeps the water and rust out.
-I like the smooth look.
Gord 🇨🇦
Found some pics showing a one piece hood but main focus was on the one piece windshield which in 2007 was our first. We allow a WEEK to weld a hood but end up with only a couple of thimble fulls of filler and zero warp. This is on a 1949 3100. Like stated the article was about the windshield. Hood also has reinforcing ribs on underside.
[img]https://i.postimg.cc/8smJFF4p/one-piece-windshield-002.jpg[/img]
Evan
If I really wanted a one-piece hood, I'd just buy one of them available from various vendors. I'm not as skilled as Evan's guys.
Just my opinion.
But if you want a "project" go for it. But be careful.
Good input. I like the 2 pc look, its unique. I think I will just leave it and move on to the next project,,,the chassis..
1952 GMC
1967 GTO
1967 Firebird
