Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
1 members (Danielbolt), 479 guests, and 1 robot.
Topics126,777
Posts1,039,267
Members48,100
Most Online2,175
Jul 21st, 2025
Looking for the part # or a place to buy the parking brake bracket that the cable attaches to inside the drum.
1953 with a 216
Curmudgeon
Curmudgeon
I don't think there is a bracket inside the drum.
There are brake cable holders (Bracket-Guide) that are riveted to the frame 3687001 L. and 3687002 R.
Good luck finding a new one.
The threaded end of the brake cable goes inside a clevis. Is this it? If not, please post a picture.
https://www.classicparts.com/1947-72-Brake-Yoke-Ends/productinfo/71-892/
Is this what you want?
Right Click on the pictures and Open link in New Tab
What does the cable inside the drum connect to inside of drum for the rear huck brakes. My chassis has huck brakes.thanks
1953 with a 216
Curmudgeon
Curmudgeon
The pictures I sent you in your previous post shows a NOS cable with parts strapped to the cable.
I added another picture. This may be what you are looking for. These come with a NOS cable.
I don't know if GMC Huck parts will work okay on Chevrolet Huck brake.
Now that I think about it, the parking brake cables for Bendix brakes are different than Huck brakes, so cable I pointed you at won't work without modifying your backing plates. There was another member here (can't remember his handle blush ) that was going thru the same exercise, converting Huck backing plates to use the Bendix parking brake cable. I'll see if I can hunt that down.
[on edit] Found the thread I was thinking of here.
Turns out he was modifying a later (56) backing plate to work with a '51 brake cable. Disregard what I said about Huck parking brake cables being different. I don't know if that's the case.
Could it be the actuating lever that is attached to the rear shoe that you need?
Yes I need the levers and shoe spreaders
1953 with a 216
Here is an exploded view of a Chevy 1 TON for reference
46-50 ½ TON
Chevy group numbers
Group 5.149 Lever 475478 R.L, 475477 L.H
Group 5.150 Extension strut 475482 R.H 475481 L.H
Group 5.151 Spring 476104
Group 5.158 Bolt 475492
I am using bendix brakes and have all the old Huck brake stuff from a half ton, PM me if you want to work something out.
1952 GMC
Starting with a basket case
In the Project Journals
1967 GTO
1967 Firebird
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.023s Queries: 17 (0.020s) Memory: 0.6419 MB (Peak: 0.7412 MB) Data Comp: Zlib Server Time: 2025-09-22 05:05:17 UTC
Valid HTML 5 and Valid CSS
