3 members (Lostbuthaulinass, Hotrod Lincoln, 2-Ton), 70 guests, and 3 robots.
Topics128,142
Posts1,056,485
Members48,441
#1445718 03/24/2022 4:05 AM
These pictures are from my 1950 4400 trucks vacuum wiper motor. I need to know if these 3 holes or passages supposed to be covered by the gasket or cut out, I can’t find a picture for the 1950’s trucks gasket set. I’m making my own gaskets since the old gaskets fell apart.
1950 4400
Curmudgeon
Curmudgeon
You didn't say what Trico vacuum motor you have so here is info for a 1950 Chevrolet truck.
Trico says it is model SSM-412-2
Pictures with handmade gaskets on ebay (need to make sure the seller is using approved gasket material).
https://www.ebay.com/itm/153900469442
Bob at wiperman.com has helped me and many recommend using him to do a rebuild.
A vacuum motor has to seal properly (gaskets, paddle surface, paddle material).
Cleaning, installing paper gaskets and oiling the paddle may be a temporary solution.
It's similar to squirting oil on cylinder walls to make a higher compression reading on the gauge.
If the wiping torque drops off after your work, consider a rebuild.
Carefully checkout the part identified by the red arrow.
I don't know the composition of the rocker but they are known to age-out, wear, corrode or break.
This part is one of the parts used to switch the direction of the wipe.
As buoymaker posted : WiperMan.com
"Pricing : Rebuilding is a standard fee of $135 which includes USA return shipping. Foreign Postage varies"
He does an excellent job.
Thanks for the help, I couldn’t find any numbers on it except for the patent numbers
1950 4400
