4 members (55shaker, ndkid275, Phak1, D B Cooper), 79 guests, and 1 robot.
Topics128,095
Posts1,056,069
Members48,433
1955 3100 1st Series - still an unrestored working truck.
The front bed panel on this truck is seriously rusted/rotted through in the panel's top roll-over. The project is to replace it with a new reproduction sheet metal piece.
Q: Can the front bed panel be unbolted and vertically lifted out from the bed? Or, does the bed need to be detached from the frame to remove the front bed panel?
1955 1st Series 3100
ol'55
I believe the front panel can be snaked out between the cab and the rest of the bed. It bolts to the bedsides and to the front cross sill, then will have to be moved forward about an inch. If there isn't enough room after unbolting it, you may wind up removing the bed-to-frame bolts and moving the bed back slightly.
This tread is a little old, but.... I just did this on my truck this weekend. The hardest part of the job, by far, was removing the nine (or ten? I think it was nine) bolts securing the front panel to the cross sill. No room to work and the nuts and bolts have had 70 years to rust together. There was JUST enough room to pull the panel out. You'll scratch paint (panel, cab, and bedsides) if you're not careful. I had two helpers pulling out on the bedsides.
Tim
1951 3100, 216, 4 speed, 6 volt
Easier to slide the bed back some?
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
