3 members (2-Ton, 78buckshot, texczech), 236 guests, and 11 robots.
Topics128,078
Posts1,056,035
Members48,433
I have made good progress rewiring my 64 c10.
The gage cluster is finished and installed. I now have to connect the speedo cable to it. It is still attached to tranny and I just need to connect it to the receptacle. With the gages installed and wiring attach it is impossible to see (andwires ) in a real tight space. Is there a secret to inserting the square cable in the dash so it slips in correctly ? I don't want to screw in the retainer unless I am sure that the cable is inserted correctly. Working blind with my my fat meat grabber hands inside that Speggitti I'm having a heck of a time.
The cable reaches but there is not a lot of slack to move it around much.
1964 Stepside C10
"Well we didn't get all dressed up for nothing." ~ Braveheart
I love working under the dash..... I know of no simple solution. Cram yourself up under there and carefully insert and tighten. Even with the seat and steering wheel removed it is a challenge I dont care to undertake often.
~ HB
1962 Chevrolet C10
1962 Suburban
I got a little space heater in the cab ( no garage) I'm crawling in there and not coming out till I'm successful.
Please send food and water if you don't hear from me in a few days.
1964 Stepside C10
I think I got it in. The retaining nut tightened I'm hoping that , that is indication I got the cable in the hole. We will see when I get it moving.
1964 Stepside C10
So you got back out from in there? No rescue party needed?
~ HB
1962 Chevrolet C10
1962 Suburban
What brand of wiring harness did you install? Would you recomend it? I'm getting to the point of thinking I need to take the leap and buy one. I have read so many different reviews it's hard to know which one.
Mark
Glad you got it. I always take the green wire for the dash light out of the socket to put in the speedo cable. makes it a little easier. Then just push the dash lights back in, they are easier to push in.
M&H is a good wiring brand, just plug and play with no need to join wires or anything. I've used them as they have nice factory look to their harnesses.
I used painless harnesses. Part # 10112. I hight recommend it. Each wire has its destination written on it. Really made it easy.
1964 Stepside C10
