1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Over the years I occasionally had a bad bolt or nut that needed replaced. I know there is the grade 5 with 3 bars on the head, and grade 8 with 5 bars. So I go to the big box store and have two choices….. either zinc or stainless steel. I know that two different metals are usually not compatible and tend to gall. I want the “black” automotive style bolts/nuts like what came in our old trucks. They also look original and don’t stick out like sore thumbs. As an example, I’d like to replace all of the nuts on top of the rocker arms. After 70 years of wrenching on them to adjust valve lash they are pretty buggered up. Where do you guys & gals go to buy this kind of hardware? Thanks
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | Check mcmaster carr. They have lots of options on hardware. Link
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Ebay has untold thousands of bolts and nuts in every size and grade imaginable. You just need to know exactly what you're looking for. Those stovebolt rocker arm locknuts will be 7/16-20, but they're about half the thickness of regular nuts. For instance: https://www.ebay.com/itm/390127261719?Jerry
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | For black-oxide bolts, I usually go to a True Value Hardware if I just need a couple or Fastenal/McMaster if I need a lot. | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Kevin, Jerry, and Fibonachu…… thanks for the suggestions and links for black oxide bolts. I didn’t really know what to call them, but now I do and where I can buy them. Much appreciated!
Jerry, thanks for reminding me that those particular nuts are different in size and are referred to as jam nuts.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Sep 2020 Posts: 449 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 449 | If you want to learn about nuts & bolts (& so much more) go to Pegasus Racing, their catalogs cover it, grip lengths, 12 point, AN, grades, nyloc, jam,etc etc, if you were building a car from scratch their catalog is the required shop reference… Probably have your jam nuts available in 12point
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: Apr 2016 Posts: 1,043 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,043 | Check mcmaster carr. They have lots of options on hardware. LinkMcMaster Carr has everything to make about anything and they will get it to you spooky fast. If you want to go top of the line ARP is the way to go. They are designed to be retorqued. A standard bolt can only be torqued once and be in spec.
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Update…. I drove to three nut & bolt retailers today looking for the elusive 7/16-20 black oxide jam nut with no luck. Only one store had any in stock, but they were zinc and the outer circumference was much larger than the Stovebolt nut. I went online and found a bag of 25 stainless steel nuts for less than $10 with free freight. My question is will they be compatible with the steel rocker adjusting screws? I’ve always heard different metals gall. Logic tells me they would be okay because of the constant drip of oil.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Feb 2019 Posts: 4,476 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,476 | I don’t believe you will have much luck finding these nuts, in the proper size and proper grade outside of the automotive trade. Personally, I would buy originals or buy the exact replacements. Not cheap, but the Filling Station has the studs and nuts as a kit. Here is a [LINK]I see them on eBay occasionally. Good luck with your search.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Put a little Never-Seez on the threads and drive on. Stainless tends to friction weld itself together when bolts and nuts of the same alloy are torqued tightly, but I don't think I've ever seen carbon steel and stainless fasteners gall when they're used together. Jerry
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Spotbiltxo If you read the GM service books I think you'll see that Chevy recommends replacing those rocker nuts,which are designed to lock in place the first install. Very much adjusting and they kinda loose their grip,gotta remember they built engines to sell !! | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | ARP and braided lines are what melted your budget and gained nothing. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | McMaster-Carr is a decent retailer, MSC Industrial Supply is better.
Probably neither will have a half-thickness nut in a 7/16 x 20, although I do not know that. as I do not need that size.
Stuff like that generally has to be custom-made. We used to put body screws in our carburetor kits, and odd sizes (13/16 instead of 3/4 or 1 inch) generally had to be special-ordered with a minimum of from 5000 up. We quit putting body screws in our kits when the U.S. suppliers went out of business. I will not use the junk.
Not a big fan of stainless fasteners; but if you are, don't EVER use them with a zinc alloy a.k.a. pot metal part (i.e. carburetor body) unless you wish to buy a new carburetor every time yours needs rebuilding. Or you just REALLY enjoy heli-coiling every screw hole!
If you find the fasteners in the correct size, but wrong finish; you can chemically strip the finish and apply the black oxide, assuming you are doing a restoration where finish is important.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 1. You will never need SS unless for shine somewhere. Pan head and oval head trims screws are SS. 2. On our old trucks, except for a few motor, driveline and suspension hardware, you can torque them as many times as you need to. 3. The only nuts you should not use twice are locking nuts. Nylon, deformed thread.... 4. When dismantling a truck or motor, always save and reuse the hardware. Lock washers can be reused if not flattened. Rusty OK, Rusted no. 5. Grade 5 is all you will ever need. 6. McMaster Carr seems to have Gr 5 black oxide fasteners. Limited length bolt choices. Nuts no problem. Large quantities only?. EBay sellers buy these and break into small Qtys. 7. Could not navigate to black fasteners at MSC Industrial Supply.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2016 Posts: 1,043 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,043 | Here is a bunch of choices for 7/16 jam nuts. They are way faster than Amazon. https://www.mcmaster.com/jam-nuts/
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You can't be faster than Amazon prime.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Bart - they have so much stuff you have to keep refining your search; but if you are patient and go through fasteners, nuts, hex nuts, hex jam nuts, and then scroll down on the left column, you will find finishes at the very bottom. Black oxide is listed.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | You can't be faster than Amazon prime. Have you ordered from Amazon lately? Prime guaranteed tomorrow delivery means between a week and never around here. | | | | | Joined: Apr 2016 Posts: 1,043 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 1,043 | I have ordered stuff from McMaster in the afternoon and received it the next day at no additional cost. It's spooky.
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | I couldn’t find black oxide 7/16-20 jam nuts for sale on the McMaster-Carr website, so I ordered a bag of 25 stainless steel nuts off FleaBay. Should be here by Saturday.
