7 members (Donf, Goach2, Hanks custodian, rfs56trk, Rusted Nut, Bill Hanlon, 1 invisible),
56
Mod | | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2018 Posts: 12 New Guy | | New Guy Joined: Nov 2018 Posts: 12 | Hi So i have torn appart my 1957 5700 lcf to rebuild the braking system and im in need of some front wheel cylinders, only markings i have found on them are 7/8 - 5454-385 any one know where to get these along with a new master cylinder? My second question is more technical, so the truck has a late model rear end from a 96 3500? Chevy dually now this has 1 3/16 inch rear cylinders would this newer rear end with brakes be compatible with the existing set up of original drums up front and hydrovac set up? Do i have any other options? Thanks James
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | what year truck are you working on? | | | | | Joined: Nov 2018 Posts: 12 New Guy | | New Guy Joined: Nov 2018 Posts: 12 | | | | | | Joined: Feb 2016 Posts: 1,995 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,995 | JDs, I have the same truck, I was able to rebuild every cylinder. Your original rear brakes had two wheel cylinders per side. The rear drums were 15x4, I think the hydro will be ok with your set-up. So your 'new' 1996 axle has either 4.10 or 4.56 gears, the original had 6.17 or a two speed with something lower than that. I replaced every brake line and hose but I have bypassed the hydro until I can rebuild it, truck stops real nice without a load and no leaks from the system. I plan on loading 100 bales of hay as soon as the roads dry up a little, we'll see how the truck acts then.
| | | | | Joined: Feb 2016 Posts: 1,995 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,995 | JDs, If you want I can get part numbers for the rebuild kits that I used although it could be slightly risky to rely on them, on my rear axle one side had different part numbers than the other side for the wheel cylinders. I'm lucky to have a parts store where they still bring out the books for difficult to find numbers. The casting number on each wheel cylinder will dictate which kit to use. After I disassembled the cylinders I soaked the casting in muriatic acid and the pistons in vinegar, honed the bore and things looked good. I did the same with the master cylinder.
| | | | | Joined: Nov 2018 Posts: 12 New Guy | | New Guy Joined: Nov 2018 Posts: 12 | Well that sounds promising, i will try running without hydrovac connected and see how it stops, i have ordered new cylinders and shoes for the c3500 rear and looking into options for the front cylinders as they are complete toast! I managed to press out the pistons and it is so heavly corroded in side the only option would be a re sleeve but this is a last resort due to $$ cost, so the hunt for new or good rebuilable ones are my next step, luckily the shoes on the front are good! | | | | | Joined: Feb 2016 Posts: 1,995 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,995 | You will have a good chance finding new wheel cylinders that will work, they may not be exact as far as the port angle but with new lines it won't matter.
| | | | | Joined: Nov 2018 Posts: 12 New Guy | | New Guy Joined: Nov 2018 Posts: 12 | I think I have found some that will fit so fingers crossed, will let you know how it goes | | | | | Joined: Sep 2021 Posts: 8 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 8 | Hi JDs I realize this is an old thread but wanted to know how did u make out with the front wheel cylinders ? I am in the same situation I rebuilt the front 2 cylinders and they continue to leak !?! Any help would be greatly appreciated Mike | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Dragging up old threads is seldom useful. JDs has not logged into the site since 11/21/18. He gone!
| | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Hi JDs I realize this is an old thread but wanted to know how did u make out with the front wheel cylinders ? I am in the same situation I rebuilt the front 2 cylinders and they continue to leak !?! Any help would be greatly appreciated Mike You didn't say what year/model your working on, but wheel cylinders are available new for many of our older big trucks from NAPOA or Rock Auto. If they are no longer available you can send you cylinders to White Post and have them sleeved and rebuilt. Mike B  | | | | | Joined: Sep 2019 Posts: 204 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 204 | NAPA has replacement slave cylinders and master cylinder. I would replace rather than rebuild. Why take a chance. | | | | | Joined: Sep 2021 Posts: 8 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 8 | Thank u “Mike” and “Chevy til I d” I have a 1957 Chevy 5700…checked NAPA they were a no go and rockauto doesn’t show anything for a 7/8” bore…I did see another thread where a “bolter” used a C60 application that had the 7/8” bore just has the inlet on an angle as opposed to straight like my setup…guna give that a try if no good I’ll contact White Post like Mike mentioned!!!! Thank u men Mike | | | | | Joined: Sep 2021 Posts: 8 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 8 | Just an update on my wheel cylinders I took Mike B advice and sent them to White Post Restoration to be re-sleeved the company was honest and direct $85 each plus shipping and estimated at 7-10 days I received them back on the 8th day They look and operate as new !!! Wish I hadn’t wasted the months of looking for new or nos Hope that helps someone !! off to bleeding the entire system Mike | | |
