1 members (Otto Skorzeny), 81 guests, and 2 robots.
Topics128,034
Posts1,055,547
Members48,425
Is there a better/easier way to get rid of rust on steel wheels?
thanks any help is appreciated, Marvin
Ask a question if you need a answer!
Resting up on Mon-Fri from Sat and Sun.
Better than what way?
Better than sand blasting?
Better than soda blasting?
Better than blasting with combinations of other blast media?
Better than chemical paint rust remover?
Have them dipped. They will come as bare steel.
Dipped in what and then cleaned with what?
back yard wrench turner
Electrolysis is another option.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Sorry I ask about my non "technical question".
WOW here we go again, in what with what.
Thank you.
Thank you.
I'm at my daughter and son in law's place. The photo is of his electrolysis setup. He just pulled a driveshaft out, and it's pretty dang clean. He uses rebar electrodes around the perimeter and hangs the workpiece from the PVC pipe across the middle. Uses a battery charger for a power supply.
