5 members (elhippie64, TUTS 59, Gdads51, 3800GUY, 68ironhead), 87 guests, and 1 robot.
Topics128,118
Posts1,056,302
Members48,439
#144281 09/22/2005 2:44 AM
1 Offline
Fellow Knucklebusters,
What was powering those late 30's GMC COE's? :confused:
I've read that GMC used Oldsmobile and other non-Chevy GM inline sixes before the GMC motor came out. I don't recall if they also used Buick or Pontiac, but I know at least one other manufacture was used in some years. I also don't know exactly when GMC started producing their own motors, but I believe it was during the 30's.
You can probably get a real good answer if you visit your neighbor at oldgmctrucks.com.
1 Offline
Oldsub,
Yeah,since reading your post,I remember something about those engines smile : .I'm not sure if it was the Pontiac or Olds.Thanks for narrowing it down,however do you have any ideas where to look for accuracy and specifics????? Any suggestions would be MOST APPRECIATED!!!!!!! wink Thanks so much!!
Ron
flathead 6 cyl. pontiac. had the indian cheifs' image cast into the head.
robert
Robert French MY3800FIRETRUCK
The Heavy Duty GMC COE's, in the late 30's,thru early 40's, used the 308, 361, 426, & 477cid. gas engines.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Olds engines and engines similar to Pontiac were used in the mid to late thirties and the 228, 248 and 256 and the 6-71 diesel engines were available in different models of GMC starting in 1939. 1940 2 1/2 ton COE 4 X 4 was a 270.
I'm looking at a GMC Engine, Parts Replacement Book, right now, from 1946, & the following GMC engines are listed, 213, 223, 228, 230, 236, 239, 248, 257, 270, 278, 286, 308, 331, 400, 426, 450, 451,& 477.
Spanky Hardy
1950 GMC 250 1-Ton
Is the 213 a 3-71?
