1 members (Bucker),
144
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 15 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 15 | Does anyone know if the brake cylinders for a 1951 GMC 2 ton truck are available from auto parts stores such as NAPA? Part numbers? As far as I know there are ones for the front wheels and two different ones for the rear wheels.
David Sword | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy dsword, please use the series number of your truck rather than the term "2 ton", it makes it easier to pinpoint the parts you are looking for. | | | | | Joined: Jan 2022 Posts: 197 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 197 | The front brake cylinder 5453780 The rear brake front 5453866 and the Rear brake rear 5453865 This is for a 350-24 1951 | | | | | Joined: Jan 2022 Posts: 15 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 15 | Jim gmc, Thanks. What I was looking for.
David Sword | | | | | Joined: Jan 2022 Posts: 15 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 15 | To answer 3B, the truck is a 1951 GMC 354-24. I think that is comparable to the Chevrolet 6000 series.
Thanks, David Sword | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy dsword, I found some jobber part numbers for the wheel cylinders you seek. Napa front UP14481 $128.99, rear forward UP 14499 $128.99, rear reverse UP 14500 $128.99 RockAuto, Raybestos front WC14481 $70.79, rear forward WC14499 $69.79, rear reverse WC14500 $69.79, hope that helps. | | | | | Joined: Jan 2022 Posts: 15 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 15 | 3B, Thanks for the numbers. I went to Napa and they were able to find the part but they were not readily available. Went to a Carquest outlet and they had the listings but could not get them. I ended up ordering from Chevs of the 40s which is fairly local to me. Their prices are about the same as Napa.
David Sword | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Don't trash the old ones. They can usually be relined with a stainless steel sleeve by a competent machinist. Jerry
| | | | | Joined: Feb 2019 Posts: 2 Moderated | | Moderated Joined: Feb 2019 Posts: 2 | Would this also be true for a 46 with a two -speed rear end or are they totally different? Thanks Norman | | | | | Joined: Jan 2022 Posts: 15 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 15 | Norman, Do you have two cylinders per wheel, or just one? Chevs of the 40s only shows up to 1-1/2 ton for 1936-1950.
David Sword | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I always take the original part numbers, and check ebay. There's one of them on there now. | | |
