0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1442021 02/21/2022 6:30 PM
Any guidance on how to move oil full flow dowel to the IN position? I have a 1957 261 with the dowel in OUT bypass position. As I rebuild, I would like to go to a full flow filter.
1957 Chevrolet 6400
Shimano #1442024 02/21/2022 6:52 PM
H Online: Content
They're supposed to be able to be driven in with a hammer and a drift punch. If it's hard to move, a little heat and a bit of penetrating oil might be a good idea. If the inside of the crankcase is flat enough, a C clamp and a socket the right size to push the plug in might be a less dramatic method of getting it to move. Once it's pushed in, getting it back out for some reason might be a bit of a challenge. One of my 261's has the bypass plug, and I'm considering trying to drill and tap the plug so it can be moved out as well as in. I'm also considering threading the hole in the block and making a screw-in bypass plug from a socket head Allen Bolt. That one will have both full flow and bypass oil filtering.
Shimano #1442050 02/21/2022 9:02 PM
Any reason you couldn't tap & put a plug in the galley as per the full flow conversion on a 236 (http://devestechnet.com/Home/FullFlowOil).
Been running a 235 plumbed that way for many years.
BC
1960 C60 pasture art
