| | | Forums66 Topics128,150 Posts1,056,985 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I got my 261 running with its early Monojet carb after engine work. I've never had a problem with that carb. It started a little rougher than before but I could idle around around the neighborhood in my 2nd gear (3rd by total count.) It just wouldn't go 30-40 MPH after shifting into high. Give it more gas, it would kinda poop out.
So I decided to pull the Monojet and install my YF 2100s that I've had as a backup for years. I noticed, though, that the 2 Monojet nuts holding it to the manifold were only hand tight!
Yikes! Could that have been the problem with it in the first place?
I'm an experimentalist at heart so I'd like to put the Monojet back on and test the theory. But there is the YF. What do you think? March forward with the YF or put the Monojet back? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Heating expansion and cooling contraction of metal parts. A new gasket settles-in. It is a good practice to recheck tightness of parts near the exhaust manifold area. A leaking intake manifold gasket can drastically reduce vacuum (flow) through your carburetor. I would test again so I could sleep better at night and not worry about it.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | This was a screw-up by the assembler, me. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2010 Posts: 10,303 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,303 | I knew a guy with a Mopar something or other with a giant thermoquad on it. His complaint was that it ran poorly while cornering hard. The bolts where so loose that you could lift one side of it to see into the manifold. It did fine on the straightaways. It is a heavy carburetor, so gravity was working with him. Monojet, not so much.
| | | | | Joined: Mar 2014 Posts: 4,508 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,508 | I believe I'd try it to see. Can't hurt anything. As has been discussed here many times, the Carter is a much more carefully and thoughtfully engineered carburetor.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The monojet carb might be too small for a 261 unless it came off a 292. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | If it's too small peak power will be down a bit. No harm, no foul | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | A Carter YF for a 258 cubic AMC/Jeep inline six will probably be closer to the right calibration, although the Monojet for a 250 won't be too far off. Jerry
| | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Generally speaking, Jeep parts are expensive; however (and I have not looked), the YF for the Jeep might be an exception. Clifford makes a 4-barrel intake for the 258, and the Jeep folks bought lots of Carter 400 CFM AFB 4-barrels for their 258. We would modify the AFB, adding the off-road Carter fuel valve. Sold a lot of them, and then a gentleman in Europe cleaned my inventory of these.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | I just bought a "rebuildable core" YF for an AMC/Jeep/International 258 for $60.00. It looks good enough from an initial inspection to run without a rebuild, but I don't put much stock in outward appearances. Another bolter I know bought a Carter "factory rebuilt" AMC YF still in the remanufacturer's box for less than $100.00. It looks brand new and he says it really woke up his 261. Jerry
