2 members (Bill Hanlon, Nuts&Bolts), 40 guests, and 3 robots.
Topics128,014
Posts1,055,324
Members48,419
Page 2 of 2 1 2
Carburetion specialist
If the vacuum advance will not hold a vacuum, then I would replace it before looking for anything else.
You may have additional issues; but fix the one you know is bad, and see what happens.
Jon.
The Carburetor Shop
Jon.
X2
My engine ran like garbage until I figured out the vac advance was toast. I doubt that is THE issue here. But might as well just knock it off the list.
If you can’t find a replacement right away, at least plug the port.
1951 3100
Putting a new vacuum advance on an engine with internal problems is like a doctor giving a patient aspirin for the headaches caused by a brain tumor. Go ahead and throw parts at the problem if you choose, but I'd "Test, Not Guess" like Sun used to promote. Disconnect and plug the vacuum line if you like, but I've never seen a bad vacuum advance keep an otherwise good engine from running well at low to medium speed.
Trying to find one now. It may take a few days.
1956 Chevy 3200
If I can't run the engine long enough to do a hot valve adjustment, would a cold adjustment be acceptable?
1956 Chevy 3200
Yes. For the purposes of compression testing, I just snug the adjusting screw to eliminate any clearance, then back off 1/4 turn of the screw to assure that the valves get completely closed. Be sure the distributor rotor is pointed at the cylinder you're adjusting to be sure both valves are supposed to be closed.
Page 2 of 2 1 2
