8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 6 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 6 | I have a 58 chevy apache 3600 with a napco 4x4 and I am replacing the front bearings and putting in new felt liners in the knuckles. Does anyone know the torque value for the large retaining nut that holds the hub on, any info would be helpful? Thanks. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I would suggest a manual: for example: https://www.classicparts.com/1956-6...oga_6QRcPLCYio9T_QFzlwsTq98aAj_REALw_wcBActually there are about 3-4 manuals ( 2 service, one parts; and a "PowerPak install manual). Just do a search on "chevy napco manuals" If it is the thread bearing adjusting nut you are questioning, it is " As tight as possible and back off 1/6 turn" as per the manual. They specify a special tool, but you can figure something out. don | | | | | Joined: Mar 2008 Posts: 6 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 6 | Don, Thank you for the information I will look up a manual. Ed | | |
