2 members (TUTS 59, Ponchogl), 106 guests, and 2 robots.
Topics128,035
Posts1,055,564
#1440275 02/06/2022 10:02 PM
Where can I buy brake lines for my 1950 gmc model 253?
forman #1440277 02/06/2022 10:14 PM
Well the truth of the matter is nowhere. But really the thing todo would be to buy a roll of the proper diameter line, flaring tool, and maybe the line ends if you cant salvage yours and have at it. If they leak, cut off end with a tubing cutter and do it again. Its not hard. Practice makes perfect.
forman #1440305 02/07/2022 2:09 AM
Check these folks. They mfg Stainless pre bent brake lines.
https://www.lmctruck.com/1948-59-chevy-gmc/ca-1947-59-pre-bent-stainless-brake-line-kits
Harold
Harold
forman #1440306 02/07/2022 2:10 AM
Crusing in the Passing Lane
CuNi line, available at most flaps works well.
Ed
forman #1443028 03/01/2022 1:30 AM
I found the CuNi to be nicer to work with and they won`t rust.
1951 1 Ton Completed
forman #1443059 03/01/2022 5:56 AM
I redid my brake system with CuNi bulk line. Got it off Amazon with an assortment of fittings. I did need one line that was larger from the master cylinder to the first division block that I used a steel line from NAPA for. Cut that one to length and bent it to fit. The CuNi line is a dream to work with and flares nicely.
Moderated by  Dusty53
