4 members (DaveV, dunfire, Dragracefan, Wayne67vert), 105 guests, and 2 robots.
Topics128,150
Posts1,056,821
Members48,456
Does anyone know where I can get a front motor Mount for an early GMC 336?
Cheers,
Craig
1953 3100 | 1958 3/4-ton NAPCO
Same part on 55-58 Pontiac and mid-50s Olds. I see them on eBay often, but today there is only one.
Search eBay for "c761748r" for the rubber mount or "GM 529880" if you are looking for the metal piece that mounts between the timing cover and the rubber mount.
I'd get both as I did have the metal piece break on my '57 GMC V8. Fan hit the shroud on gentle acceleration and left turns.
