7 members (3B, Phak1, 1955 1 Series, Gib70, Joe H, KEVINSKI, 1 invisible),
133
Mod | | | Forums66 Topics128,092 Posts1,056,451 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 5 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 5 | Does anyone have a source for pre bent sheet metal? Especially the fender parts. Thanks for any info!
1957 Chevrolet 6400
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | some of the fender parts are real similar to the std pickup fender parts (patch panels). I think we are stuck with either finding used, or new pickup parts and using what we can to repair ours. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Welcome to the Stovebolt  Your 1957 6400 is a one year fender that was used on the 4000 and 6000 Series trucks only. The 1955-56 fenders will not fit as the front axle was moved 2.5" forward for the '57 model year due to the larger size tires hitting the firewall. Pickup patch panels are not going to fit with the exception of the one for headlight area...the heal, wheel opening and grille area are all different. Fabricate your own patch panels or look for better used. Mike B  | | |
