6 members (46 Texaco, 55shaker, J Lucas, PAUL Berardi, Otto Skorzeny, 1 invisible), 70 guests, and 4 robots.
Topics128,083
Posts1,056,327
Members48,442
#143972 08/19/2005 4:07 PM
Just did a clutch job on my 37 1 1/2 ton and as I am now buttoning things up I need to know what to lube the carrier with? When I took it apart to pull the tranny there was some, but not much, gear lube in there. The joint is in great shape with no signs of wear. Let me know what you Big Bolt Torque Tube guys are doing! Thanks
#143973 08/19/2005 4:47 PM
Most carrier bearings are sealed, but you can work a little wheel bearing grease under the seal lip sometimes. A big hypodermic syringe and a horse-sized needle might come in handy, just slip the tip of the needle under the seal lip.
