7 members (cmayna, DadsFirstPickup, 68ironhead, Woodcmiami, Bill Hanlon, truckernix, Otto Skorzeny), 94 guests, and 4 robots.
Topics128,259
Posts1,058,297
Members48,485
My 53 Chevy had the top bar painted when I got it almost 20 years ago. Reading old posts supposedly there were no chrome ones for this year(?) . Pretty sure this one is original but someone ended up painting the top bar. The other bars are in pretty good shape; anyone have luck just disassembling and getting one bar re-chromed? Also I tried the Juniper Green paint color on a fender which was a standard color for 1953. and it`s not a close match. My next attempt will be Forester Green which was discontinued in 1952. Any chance the factory might have been using up forester green on early 53 models?
Last question This valve cover from a 1961 engine seems to never had paint on it. Were all valve covers painted when they left the factory? any help appreciated.
1953 3100 Pu
I thought that '53s didn't have chrome grilles either. Maybe someone changed it out, like they added the amber lights below the headlights.
That top grille bar looks pretty funky. Its not that hard to remove the top grille bar, but you may have to remove the lock panel behind it to get to the fasteners.
I suppose it's possible that it was repainted Forester Green before you got it. 20 years isn't that much of it's lifetime. Someone obviously painted that top grille bar.
Valve covers were painted with the rest of the engine, but a lot of them I've seen have had the paint peeling.
Is it possible someone had a mishap with one of the chrome bars and used a painted replacement, moving the replacement to the top for a less noticeable position..
2 Offline
All the bars are unique you cannot interchange the positions or else your eye will catch it and the whole think will look wrong just enough to be annoying but it won’t be obvious to many why it’s wrong.
The top bar is very different it has the top edge for the panel that holds the hood latch it can’t be swapped out to a lower position incorrectly even if you tried
-s
$250.00 for re-chroming the top grill bar! Triple plating...but ouch! I repainted the bar in the photo to test the Juniper green, it`s in good shape but I will probably go back to original color although I`m sure it would look better either all chrome or all painted
1953 3100 Pu
I've seen a grille that was powder coated with chrome. It looked pretty good and was way cheaper than actual chrome. That would be an option versus $250 for one bar. big_eek
Crusty Old Sarge
Crusty Old Sarge
Have you placed an thread in the Swap Meet forum for a grill bar? I'm sure someone must have an old grill with just one decent bar on it.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Powder coating chrome is a good durable option as Kevin said.
