3 members (kbenz, JW51, 1 invisible), 218 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
Well, dang. I buggered up the threads trying to get the pulley nut on. Does anyone know the thread size so I can get a tap and die set?
Dennis
40 Chevy 1/2 ton
Moderator, Electrical Bay
As I recall it is a 16 x 1 metric. Find a metric thread size gauge to check me on that. Good luck...not an easy re-threading job.
~ Jon
If I'm right on the size, get a split die like this one: https://www.globalindustrial.com/p/...adjustable-die-fine-thread-1-1-2-inch-od
That way you can start at the end closest to the alternator, tighten the die and work it backwards to the distal tip of the shaft. Then just buy a new nut.
~ Jon
Might be able to use a thread file, or just a triangular file, if just the first few threads are buggered up. If you can get the nut started straight, you'll probably be OK.
I'm not sure you could get that adjustable die over the threads, even if stretched out all the way.
You could cut the nut in half and clamp it on the alternator end and unscrew it to clean up the threads a bit. Of course you'd need a new nut.
I think it was 59fleet that came up with that idea for wheel studs. thumbs_up
Once you determine what the thread diameter and pitch is, find a hex die that size, cut the die in half and use a socket to back it off of the shaft. You'll trash a die but you'll save the alternator armature.
Thread pitch gauges & thread file.
BC
1960 C60 pasture art
Thanks, that gives me some options. I've sent off for a thread pitch gauge. Needed one for a long time anyway.
Dennis
40 Chevy 1/2 ton
Crusing in the Passing Lane
Most hardware stores have a thread pitch gauge placed somewhere near bolts!
Ed
Dennis m That thread has been the same for decades,unless its demolished should be able to file off the burrs.
Dennism In another life when I was an alternator rebuilder we had a die to chase "core barrel" bites off of those shafts.
