5 members (‘37ChevyPU, Steelonsteel, carbking, MickeyP, Gray_Ghost), 75 guests, and 1 robot.
Topics128,051
Posts1,055,766
#1439193 01/28/2022 10:12 PM
I have a GMC 336 that I'm using in a 1958 GMC 3/4 ton NAPCO I'm restoring. The engine is in the shop now. Anyway, the guys at the shop called me and wanted to know if I had an early, mid, or late GMC 336? The block serial number is 33603131. I believe this is an early block based on the Pontiac 370. It also has completely dished pistons. Not the partially dished pistons. Block casting number is 530046. Just wanted some verification from someone "in the know" to make sure I'm correct before I tell the shop to order engine rebuild kit. Appreciate the help.
Cheers,
Craig
1953 3100 | 1958 3/4-ton NAPCO
The only reason to run dish-top piston is so a truck can haul a max weight cargo load at wide open throttle, lugging the engine down while burning the cheapest grade of regular gasoline available without running into detonation problems. Unless you're building a truck that actually works for a living, not a Cowboy Cadillac, run a set of flat tops that fit the bore and stroke and get the benefit of a little more power.
Moderator, Electrical Bay
You're right. That is the early one. The later one was based on the Pontiac 389. I can't remember if it had dished pistons, but I don't think so. I also think the bore and stroke on the 2 may have been different. But I could be wrong on that. Haven't had one of those apart since around 1972. All the later ones had a problem with oil leaks where the oil filter mount attached to the block. I remember that very well. Wasn't easy to fix, either.
~ Jon
Carburetion specialist
C Online: Content
Never worked a truck Pontiac engine, but Pontiac passenger engines like flat top pistons.
Jon.
The Carburetor Shop
The early 336 V8 (engine serial number less than 336035000) used '58 Pontiac 370 crankshaft dimensions while the late 336 V8 (engine serial 336 035001 and up) used '59 Pontiac 389 dimensions. Never heard of a "mid 336".
Picture shows the location of the engine serial number on the passenger's side of the engine.
