5 members (Randy Baumann, Rudedog53, Spikeytop, 50Chevy3100, Otto Skorzeny), 81 guests, and 5 robots.
Topics128,181
Posts1,057,191
Members48,465
Page 2 of 3 1 2 3
Thanks Kevin, I see the 10-3/4 clutch kit is out of stock, also I don't believe NAPA ships over the border, but I will inquire. For the trans bearings, They do show different models from front and back main shaft, so looks like they recommend a 6308NRJ. I will have to look up the difference between this and the 6209 I was originally told.
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
So, my apologies to anyone following this thread looking for bearing confirmation. The NAPA site only states a 'manual-4 speed', but doesn't actually state SM420 for the 6308 bearing, plus the recommendations is for the countershaft. I'm going to stick with the 6209-NR for the front main shaft and will post the comparison when I have them both in hand.
More images
Bearing is ordered and on it's way. Figured I'd ask one more time about stealing the nice non-brass synchro out of the later model trans? Or keep the original with wear?
More images
Just buy the kit, Ive used many of these.
rebuild kit for sm420
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Finally got my trans pulled apart. Here is the old and new front bearings side by side.
[img]https://www.stovebolt.com/ubbthread...umber/38973/filename/20220122_211710.jpg[/img]
Is less bearings a bad thing? The dimensions seem to match...
More images
As long as the dimensions are correct, either one should work OK. A SM420 is about as bulletproof a transmission as you're likely to find. The rock crawlers love them!
Oh good news. I also wanted to see if this ring looks ok still or too warn?
[img]https://www.stovebolt.com/ubbthread...umber/38986/filename/20220123_094955.jpg[/img]
Also, Is it possible to be completely missing a key? I can't find it anywhere, but there was a big snap ring in the bottom...
[img]https://www.stovebolt.com/ubbthread...umber/38987/filename/20220123_122304.jpg[/img]
More images
That "key" is not missing- - - -it's broken, which probably is also the reason for the damaged corners of the slots in the brass ring. The annular rings that actually grip the taper on the gear and match the speed during a shift are about halfway worn out- - - -they should come to a sharper point. That ring you found in the case is actually a spring that fits into a groove in those keys and pushes them out into the sliding shift collar. Bottom line- - - -you need a complete synchronizer assembly, or at least new keys, a spring, and a new blocker ring. Those parts might be a bit hard to find unless you can scavenge up a good used synchronizer.
Good information, thanks Jerry. I do have this slightly newer trans with rings that still look like new:
[img]https://www.stovebolt.com/ubbthread...umber/38990/filename/20220123_134511.jpg[/img]
What are the chances I can grab this ring and keys?
More images
I'd suggest swapping the entire synchronizer assembly, including the sliding collar that the shift linkage engages. That rust will polish off with a little bit of work with a wire wheel on a bench grinder. Mixing and matching synchronizer parts, except for the brass blocker rings, is seldom successful. I always put a small scratch mark on the mating pieces of the slider assembly with a diamond-tipped scribe so the wear pattern of the male and female splines isn't disturbed.
Can do Jerry. The sliding collar is different from the original, that ok?
[img]https://www.stovebolt.com/ubbthread...umber/38992/filename/20220123_154903.jpg[/img]
Also, some of the later front shafts don't leak out the front, is it worth possibly swapping the whole front?
More images
I think some of the later model front bearing retainers (the part the throwout bearing slides on) have a lip seal included. The input shaft would need to have a smooth surface for the seal to ride on. I believe the earlier ones had an oil slinger up front instead of a seal. As long as everything bolts up and the shift linkage works OK, mixing and matching parts from different years will probably be OK. Just be sure all the parts move through their full range of motion without any interference. The synchronizer sleeve with the tapered collar and the squared-off one on the later assembly should interchange, as long as there's no mechanical interference with anything. Good luck!
Thanks, I'll need it. While I'm salvaging parts, is this an issue I will need to deal with?
[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/38995/filename/Gears.jpg[/img]
More images
Those teeth don't look bad at all. most of them have the right angle, and there's very little chipping on the ones I can see. Also look at the internal splines on the sliding collar that meshes with them- - - -the leading edges of those teeth should look similar, with a minumum of wear.
Ok, here's some good info if anyone is ever doing this in the future:
Spare trans has the rubber seal
[img]https://www.stovebolt.com/ubbthread...umber/39002/filename/20220123_175141.jpg[/img]
The first rings are not the same
[img]https://www.stovebolt.com/ubbthread...umber/39003/filename/20220123_180006.jpg[/img]
[img]https://www.stovebolt.com/ubbthread...umber/39004/filename/20220123_180016.jpg[/img]
And the ends of the input shafts are different
[img]https://www.stovebolt.com/ubbthread...umber/39005/filename/20220123_180131.jpg[/img]
So, looks like I'm using the donor shaft and synchro rings. I will use the keys from the donor too, but in the original gear.
More images
Last year I changed the 4.53s in back to 4.11s. The donor trans came out of a TF truck, pretty sure a 1/2 ton. Any chance swapping out the speedo gear would give me a little more speedometer accuracy?
[img]https://www.stovebolt.com/ubbthread...umber/39013/filename/20220124_102816.jpg[/img]
More images
Way back in the dark ages, there were speed change gearboxes that were used to correct speedometer errors. They were attached to the transmission and spun the speedo cable at a different speed, higher or lower. Internal gearing in the small rectangular box could be swapped to get the right speed correction.
Ok, I think you're saying; 'keep the original that you know works and get an adapter' smile
More images
Big Bolt Forum Co-moderator
I noticed someone mentioned earlier in this thread that big trucks had the e-brake on the driveline. My two ton definitely has the original transmission (because it still has the red paint on it to match the cab. it was in fire service to begin with) and it has the e-brake on the rear wheels. Any one have a definite idea on why some were on the rear wheels and some were on the driveline. I have a spare tranny that does have the driveline e-brake.
1948 Chevy 2-Ton
You fire truck had it's factory trans mounted parking brake relocated to the rear because you have/had a mid mounted pump with a transfer case that disengages the rear axle when pumping, this allows the pump to turn and keeps the truck from rolling away...the parts for the parking brake may or may not be GM parts, the fire service body builder may have used parts from another manufacturer.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Any concern about the spring retainers under the clutch keys moving around and letting the key drop? The retainers are just barely long enough to hold all three in place. What are the chances that a sift in the ring caused me to lose the original key? Anyway to test their still in place after it's installed?
[img]https://www.stovebolt.com/ubbthread...umber/39116/filename/20220127_124944.jpg[/img]
More images
I have a tranny that I could not get apart if you want I could snap a few pictures .in your picture I can’t see the ring you are referring to .The picture you took is the gear cluster that I have out of the transmission case.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
There two snap rings, one on either side of the hub. You can only see the 'inner' one through the clutch key holes. It's the same size as the outer one and it just barely touches all three keys. I'm just concerned that it might slip off of one and cause the key to fall out. It would only be about 3/8" movement to expose one key...
More images
Here are a few pictures of the one I have if it helps.
"The Journey"
Follow in the DITY
Thanks for those. Getting ready for reassembly now.
[img]https://www.stovebolt.com/ubbthread...umber/39196/filename/20220128_142311.jpg[/img]
For the gaskets, should I smear a light permatex on? The front spindle is just thin paper, give it a smear too?
More images
I'm a big fan of Permatex 2 Form a Gasket...I always use a light smear on paper gaskets that are sealing oil.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I bought ES 72843 for the rear propeller shaft assembly. I understand I need to shim out the ball joint to ensure a good fit and the cork seals around the ball. But what's the rubber ring for?
[img]https://www.stovebolt.com/ubbthread...umber/39225/filename/20220129_143615.jpg[/img]
More images
That's the seal for the rear of the ball where it slides over the torque tube.
The 'ball' is part of the torque tube and seals to the trans socket with this cork seal:
[img]https://www.stovebolt.com/ubbthread...umber/39226/filename/20220129_145325.jpg[/img]
But can't find anywhere the rubber fits, except maybe with the dust shield on the other end?
More images
Most likely on the other end under the cap that screws on
"The Journey"
Follow in the DITY
Under that cap I believe there are also some washers that squeeze the seat tight .the original was cork .
"The Journey"
Follow in the DITY
Ah, ok that's a different setup than mine. Probably don't use it then.
More images
Dinked again! Bolt holes are different on the front cover! Not sure where to go from here...
[img]https://www.stovebolt.com/ubbthread...umber/39228/filename/20220129_151248.jpg[/img]
More images
Is this the difference maybe use the newer case.
"The Journey"
Follow in the DITY
Ya, to use later synchro, you need whole front shaft. Front shaft not compatible with earlier models without seals. Either I drill/tap new holes, or keep looking for synchro's.
More images
The one with the seal is the way to go as it won’t leak oil if you are parked on a hill like the Novak site explained .Can you use the newer case that matches the front cover .All the gears I would think fit .worth a try although more cleaning
"The Journey"
Follow in the DITY
Ya, that's the only advantahe that I can see for the later model. My first choice is to replace the synchro and button it up. Will see what I can find...
More images
Managed to find an original in good shape on the 'Bay'. Not cheap, but hopefully it will come in soon and I can finish the transmission up!
More images
More images
Goach2 If it was mine would find a drum brake for the open driveshaft system and use it,that way you'll have a great lever brake and modern u-joint system. when you find the drum brake a bolt in drive shaft may be there with it. Also the lever brake will hold a pretty good load because it's working thru the differential gear ratio's. only down side is may need to re-line the drum brake,have been studying that 'cause mine needs it !!
Page 2 of 3 1 2 3
