| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 11 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 11 | Does anybody know what size clutch head socket is needed to remove rear fender bolts on 1954 gmc 100 ? | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | I believe it's the 1/4" size. But the driver's come in sets. You'll likely need the other sizes as well, so just buy the set.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2022 Posts: 11 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 11 | Good advise ! Thank you. I found a good USA made set on e-bay. They’re on the way. Thanks again Jeff | | |
