6 members (3800rao, IHPWR, Lightholder's Dad, Leo, Gdads51, 1 invisible), 84 guests, and 4 robots.
Topics128,087
Posts1,056,344
Members48,442
I am rewiring my 50 GMC and need to find out where the parking light wire routes into the engine bay, I see no holes in the inner fender that looks to be right.
They don't go thru the inner fender. They go from the terminal block around the inner fender between it and the radiator support. Here's a couple pics from my '51. This is the right side, and the left side is similar. The parking light wire is the rearmost one on the terminal block that goes under the wires to the headlight thru the inner fender.
Parking and headlight wire through inner fender on 1950 GMC 1/2t
forman There is a gap at the radiator where the wite goes thru.
GMCs are different than Chevys with the parking light in the fender below the headlight. Showkey's pic shows the parking light wire going thru the same grommet as the headlight wiring.
